Grumble
- stormingjoe
- Contact:
Grumble
Clutch in nice and quiet in neutral, clutch out I can just make out a light grumble from the primary drive/gearbox shaft area only notice now that I got some DB killers in the exhaust. Just wondering if normal as twins do tend to give out unusual noises!
- Phil-VTwin
Re: Grumble
yep...... that sounds familiar !
- stormingjoe
- Contact:
Re: Grumble
Ok then normal fine by me
, just noticed now the viper noise is reduced
cheers chaps for replies
Re: Grumble
Last engine didn't do it, this one does, it was newer and had less miles. Go figure.
All Hondas are a bit susceptible to a little clutch slap, ignore it.
