Need to renew the plugs. Now theres so many different types out there and I ,m sure every one uses different kinds. Which is the best plug for a storm that is used all year and stays outside with cover over it during the cold periods.
Rick
Which Plugs
Re: Which Plugs
I think most people use the standard plug, which is DPR9EIX-9, or if you have a lot of cold weather starts sometimes the DPR8, which is the varadero spark plug works quite well.
- Pete.L
Re: Which Plugs
Sound advice,
I'd get the DRP8 if there's going to be any winter use. It just starts soo much easier. Oh! and get the irridium ones, cost a bit more but they last/perform better.
Re: Which Plugs
Cheers guys. O us ethe bike all year so cold weather starts are the problem. Looked at the iridum ones but wasn,t to sure which part number to choose, seems so many different types.
Again Cheers for the advise
Rick
Rick
Re: Which Plugs
Hi Rick, the best plug for the Varadero is the NGK/DPR8EIX-9, which are quite pricey at around £10 each- you can have a "loan" of the 2 that I've got for the winter if you like, let me know if you're interested as I don't use them unless it's exceptionally cold here.
Re: Which Plugs
Many Thanks for the offer Chris. I.ve found some on ebay for around 14 squid. I take it these will be ok for winter use but will I have change these over as the weather warns up next year.
Rick
Rick
Re: Which Plugs
All sorted , 2 new iridum dpr8s on there way. All in with postage 14.20 So brake and clutch fliud free K&N air filter being fitted in the next week or so by me nice local mechanic all for 25 pounds .
