Damn fork seal leaking/popping
Honzuki
Post by Honzuki »
OK, bought the VTR back in July with a leaking right hand fork seal, but the price was good so I thought it wouldn't be a problem.
I replaced the fork seal with a Pyramid (2 springs) one off Fleabay. I managed about 500 miles when it went again big time and emptied a load of oil all over the disc and wheel just as I stopped at the MoT centre, nice!
So I take it to a trusted 'old school' bike mechanic who finds a slight nick in the chrome quite a way up the leg. I pissed that I hadn't noticed it myself TBH! He has a go at smoothing it out with some wet and dry until he's happy that it's no longer a problem. Rebuilds fork with another Pyramid seal and off I go.
Another 300 miles and I notice dust sticking to the right leg. Looks like it's leaking again, very slightly at the moment, but I think it's going to get worse.
I'm begining to wonder if there's something more to it than a slight nick in the chrome. Even with that 500 miles seems a very short time for a seal to go.
Has anyone had any similar problems?
Failing that does anyone had a set of good forks that they might be willing to sell?
Cheers T
stormingjoe
Re: Damn fork seal leaking/popping
Post by stormingjoe »
use genuine seals, common problem on non genuine items
bikerpiker
Post by bikerpiker »
I had big problems when i used Genuine Honda dealer fork oil seals ,which had 1 spring ,...my problem was sorted by using pyramid oil seal(from ebay),with 2 springs,.......which turned out to be made by the same manufacturer as the genuine Honda items ,with NOK(manufacturer) and identical part numbers stamped on the seal.
I even took my forks into the Honda dealer ,to show them how slack the genuine Honda seals were ,ie , when holding the oil seal with the fork through the hole in the seal,the weight of the fork slipped down through the seal ,ie it was slack!!...with the Pyramid oil seal ,it was tighter,and when lifted ,the fork did not slide through the seal. (that maybe sounds hard to understand, but i know what i mean) :)
Clicky .. http://www.vtr1000.org/phpBB3/viewtopic ... als#p85115
Stevie
Jonesey
Post by Jonesey »
+1 on using OE seals, did mine 3 years ago and have had no problems since.
I believe that the seals from suzuki rm 250 fits too, they might be listed as cheaper even though they're the same part number.
Failing that, if it's just 1 seal you need I think I've got 1 somewhere....
Check the friction metals on the end of the stansion. If they are worn it will keep popping your seals.
Honzuki
Post by Honzuki »
Thanks for the tips guys and for the offer of the single fork seal, but I'm beginning to think that a full rebuild is going to be needed and I may as well get both done.
I think that there might be a problem with the stanchion Can anyone recommend a decent aftermarket supplier?
L&M do a re build (clicky) that looks like a good deal for the money.
Unfortunately lack of a garage and time means that I'll be having to pay someone else to do all of the work! :mad2
stormingjoe
get them rogered!!!!! with new bushes etc
stormingjoe wrote:get them rogered!!!!! with new bushes etc
+1 on that :thumbup:
Give Roger a call and see what he recommends, that would be my advice
http://www.revolutionuk.co.uk/
