Thanks
Jimmy
I could do but that would mean i have to change the paddock stand around all the time, the simplest way in the long run is to fit bobbins to the Storm. I gather nobody uses paddock stand bobbins then?Zakalwe wrote:Can you not get some cups that fit under the swingarm?
Better still...ditch the paddock stand and get an Abba stand
+1LotusSevenMan wrote:Tony.M
LOVL.
I think you'll find that is a marker that says 107mm from the rear end of the swing arm and 25mm up from the lower edge is where the bobbin centre is!!!
