Standard baffles-just drilled or out altogether?
Re: Standard baffles-just drilled or out altogether?
Worth checking it on the dyno as it'll probably run lean now.
You can offset the effects by using a K&N or similar, but a Dynojet or Factory Pro jet kit will be most effective.
But as long as you do a plug check in the first few days you shouldn't do any damage- the risk though is that it'll run lean and burn a hole in a piston or burn out a valve seat.
However, please don't panic :wtf: - I'm just outlining the worst case, it'll almost certainly run for years without problems, even if it's running a bit lean.
IgorVigor
Post by IgorVigor »
I'm going to check the plug today, but it doesnt feel lean...
Its completely stock intake apart from 33bhp restrictors which made it run very rich...
So much so that the plugs were always black, and the bike spluttered petrol out the pipes a bit...
Not any more though :D
Twinpotter
Post by Twinpotter »
Reading this post, I removed the restrictor rings on my Harpoon pipes.
Ooooooooooooohhhh.
motorola222
Post by motorola222 »
spit flames maybe some vids of the overrun?
Jonesey
Post by Jonesey »
Twinpotter, any chance of a pic of those harpoons?
geodude
Post by geodude »
Finally bit the bullet and completed the bafflectomy of the storm today. OMG what a difference. I keep thinking "How long will it be before getting pulled" but then think "Some Harleys are stoopid loud so I should be fine." It sounds how it should now and i'll keep it that way untill I can afford some proper cans :)
Just need to tidy up the insides.
benny hedges
Post by benny hedges »
you're more likely to get pulled for that number plate :roll:
you can buy some cheap db killers off fleabay for mot day :thumbup:
chojindan
Post by chojindan »
Mind if i have a listen at some point geodude? :)
Looking to do this myself at some point!
geodude
Post by geodude »
dont mind at all. let me know when. probably after work would be best.
once you hear it, you'll do it i'm sure. :biggrin
I'd only add that I recently had to swap back to the standard ones from my Carbon Can Co ones (MOT-just for a couple of hours, obviously :D )
And once again I was struck by how heavy the standard ones are- all that extra weight..... :thumbdown:
So even though a bafflectomy is cheap, because you might still want a standard pair for the MOT you might be better off buying some non-marked race cans.
And the standard ones make the footrests vibrate!
One last thought- if you want to quieten race cans (Track day? Complaining neighbour? Producer?) you can always bolt in some DB killers- can't do that with a bafflectomy'd set.
benny hedges
tony.mon wrote: you can always bolt in some DB killers- can't do that with a bafflectomy'd set.
dunno tbh, reckon you could get some made up to fit for the big day.
that 'getbidding' seller on ebay who does the dodgy welded ones will make them up to any size for the same prise - tenner each.
even if they look sh1t, as long as they work....
mot tester might not bat a eye tbh
bikerpiker
Post by bikerpiker »
Heres a before and after pic of mine.......for the MOT i made a wee bolt on round plate ,with a wee bit of hollow pipe tack welded on.
Passed the mot test no problems ,and fair quitened the bike down.
Stevie
benny hedges
how the hell did you manage to get your bike in the garage sideways! :confused
bikerpiker
benny hedges wrote:how the hell did you manage to get your bike in the garage sideways! :confused
I didn't ......that was a up n over garage door i got from' Escocia'(forum member)to replace my old fooked wooden doors. It was just placed up the lefthand side of my garage until i got round to fitting it :)
Stevie
andre5030
Post by andre5030 »
Just preformed a bafflectomy on my stock cans and gotta say very happy with the results. Not too loud at all imo just right with that nice deep tone put a smile on my face anyway. :D
Had a bit of trouble getting them out so banged a big chissle into the pipe and twisted it with vice grips and it came out no bother, although left a slightly bigger hole in the inside plate (not exactly round).
Only drove it 3 miles from my bro in laws house so need to get a good test run yet.
