After looking at some pics i took of the head to show the bent valves i deduced it was the dowel opposite the cam tunnel that was missing...another look around the floor on that side of the bike and its nowhere to be seen.Then i looked at the open end of the exhaust downpipe and thought surely it aint fell down there...i tapped the bottom of the pipe and i could hear something rattling around...oh well exhaust off then and tip it out,only the rear connecter which goes up to the rear cylinder was seized solid and a 10mm socket would not go on and a 11mm just slipped round and round...damn what now?
I have a big magnet so i put that on the downpipe and thought it might slide up to the top of the pipe with the dowel sliding inside...no chance,so i got a small magnet and attatched it to a peice of wire then wrapped insulation tape round it to make it less likely to just stick to the inside of the header pipe and then lowered it down inside the header pipe...it still stuck to the sides ! so i used the big magnet to pull the smaller one down and it worked...down went the smaller magnet on the end of the wire.I took it right to the bottom of the header pipe then removed the big magnet and pulled up the wire and there the little bugger was stuck to the small magnet
Just got my parts from David silvers literally minutes ago so i can now get on with the rebuild...can't wait!!
Al
