Anyhow, have swapped them out following the good instructions on here
So before I start the bike for the 1st time, and wonder if they are too tight or too loose and if they have been swapped out correctly, I was wondering if there is anybody on here who has experience with manual adjustment, and possible lives in close enough proximity to North Fife willing to donate an hour of their time to come and make sure that they are set properly.
Kettle is always on. Garage is bright and dry, so evenings are an option.
Any help or advice would be much appreciated.
ps, Once the bike is all back together, access to adjusting the rear is not really an issue, but exactly how do you get past the coolant hose to make enough room for the spanners to adjust the front.
I locked off the old ones when removing and both front and rear were about the same. 57mm. Manuals were set to near this and then adjusted slightly when installed to what I thought felt like a suitable tension on the rear chain, by feel and looking at the chain position relative to what it was before. The front was then adjusted to what I felt was the same tension.
