Hi guys just a few questions.
1) If I was to get custom brake lines made what length do I need for the 2 fronts and rear?
2) What size flush mount indicators do I need for the front to cover the hole or ones that sit in the hole?
Thanks
Robert
Indys and Brake Lines
2000 Firestorm
Re: Indys and Brake Lines
First, try searching the Workshop Knowledgebase.
Indicators subject occurs many times, down to personal preference. You might want to look at other people's bikes in Pimp My Ride section.
Re replacement lines, just order the right ones from whoever you want to buy them from- all manufacturers quote the Storm spec.
You only have to establish length if you're making up some form components- then make sure you get SS banjos not alloy, they can be a MOT failure and go furry quite easily.
If you're going to get some made, why not just take your originals in as a sample?
