Unfortunately it didn't seat properly so when I tightened everything it got trapped and has cut the ring. So it will no longer seal
Is there anything else I could use to replace or supplement the ring until I can get a replacement?
I'm in Kent. Will try Honda dealer but worried that it may not be a stock item, and I need to use the bike on Mondaybenny hedges wrote:whereabouts do you live m8???
i use a place called EAP in bury for o rings and seals, but any Eriks, wyco or bearing dealer should be able to help you out.
or a honda stealer...
That's exactly the sort of answer I was hoping for, as I'm planning on getting through the tunnel to Southend on Monday with my sons, so thankstony.mon wrote:Personally, I'd take my chances with just sealant and whatever o-ring is still useable while the correct part is on order.
Better that than miss the Easter runs, if it's not raining where you are
