right, looking at the bike when it's propped upright, it's clear the mudguard has gone cos it's been twisted, but the fork stanchions LOOK straight.
without removing the fairing and wheel, forks etc i can't tell if they are slightly bent.
but with the wheel pointing dead ahead, the bars and yokes are at 1 o clock.
with the front brake on, sat on the bike, if i pump the forks down they seem normal and the wheel doesn't twist to the side etc...
one (vfr) bar has moved a bit on it's clamp, but apart from that, could it just be that the stanchions have moved and twisted slightly in the yoke clamps, and all i need to do is undo the bolts and twist them back straight???
reason i need to know is i have an assessor coming tomorrow so i don't want to remove or adjust anything until he's seen the damage, but there is a good set on ebay due to end in 8hrs.
also, if it comes to replacing the front end, i might as well fit a fireblade set for the better handling, unless you can suggest something better that will go straight on...
i want to keep the bike but if the forks, yokes, frame, swing arm and subframe are all gone, as well as the fairing, tank, mirrors, indicators etc, it's looking like it's a lost cause and maybe i should just ride the cbx until i get weighed in and get myself an sp, which is what i wanted in the first place....
oh i dunno!..
main point is, are the forks just out of alignment in the yokes and can they be twisted back?
any help gratefully noted.
