Any one know the Part number for the Honda CCT tool?
Ta! Chris.
Honda CCT tool
Honda CCT tool
- benny hedges
Re: Honda CCT tool
no part number, but i can give you his phone number.Jonesey wrote:Any one know the Part number for the Honda CCT tool?
Ta! Chris.
Japan TEL: 81-(0)3-3423-1111 (Switchboard)
- Phil-VTwin
Re: Honda CCT tool
Dont think anyone has ever bought one Chris, how to make one is in the manual, a piece of 1mm steel and a file
Ride Safe
Phil
Phil
Re: Honda CCT tool
Never needed to use it; if you want to know how much of the plunger is inside the engine so you can set a manual just count the number of turns from fully retracted.
If it's just to remove it then just undo the mounting screws slowly, a turn each side. The spring isn't very strong so you can hold it in by hand. Set the engine in the right place before starting.
But if you really need one I can post you one, they come with every replacement new CCT.
