Hi all just put some replacement downpipes on the storm to replace ones that were blowin through a dodgy weld. Now I am gettin lots of poppin and backfire
on the over run, all comin out of end of cans (which do need repacking). All was fine with the old pipes, was this because they were blowing and will repacking cans make a difference?
Thanks for looking
Matt
popping an fartin
- benny hedges
Re: popping an fartin
have a feel around the manifold where the link pipes join - might be blowing a bit.
if it is, put a bit of that gun gum stuff on it and tighten it up a bit.
Hey Matt, you could check a couple of things:
Are the Graphite gaskets that seal the pipe sections together in good condition?
And are the clamps that go round the pipes perfectly round?
I agree with Benny, seems you are definately pulling air in somewhere.
Make sure things are all tightened up properly, but whatever you do, don't overtorque(problem my missus suffers from).
Hi
Have ordered some new cylinder gaskets I cant imagine its sucking air anywhere else. Will stick some gun gum on it tomo for the time being.
Thanks
Matt
Thanks
Matt
- Pete.L
There's a hidden joint on the rear exhaust down by the shock if yoou haven't found it. That's a favorite one for leaking and causing popping and banging. Worth a look
oh eck.............when i read poppin an farting, I thought it was a party invite................
it may be clever, but its not big.
