does anyone know the purpose of this orifice plate / restrictor in the intake rubber of each carb???
it is 46mm internal diameter - but the carbs are 48mm bore...
need an answer before i grind it away and polish it up to 48mm lol
i'm wondering if it is there to collect fuel on the over-run but seems unlikely.
both intakes are exactly the same, with a slight oval section that goes to the edge, the rest of it restricts the intake by 1mm all round...
