new rear end arrived!!!!!!!
vtrmann
Post by vtrmann »
Just to update all my new bits are here, for the single sided conversion, just need to finish dissasembly of the stock arm etc and sell it all. with any luck and a few beers it could be together by weekend?
undertray and plastic has sold
exhausts under offer
technoflex shock will be off tonight
single sided swing arms rule....!
chojindan
Re: new rear end arrived!!!!!!!
Post by chojindan »
Pics!
We want pics :lol:
vtrmann
Post by vtrmann »
will be uploading pics this weekend, it should all be test fitted then dissasembeled for paint and polishing etc before final assembly.
vtrmann
Post by vtrmann »
hi, its all sorted now, exhaust is made 2 into 1 and a single twin exit oval can under modified standard tail unit. as for the suspension linkage, i have lined it all up with my laser sight and i will be able to just enlarge the smaller of the two tank bracket holes to 12mm and use a 12mm nut and bolt for the original top mount hole......unless theres another way?
