Leo Vince - need help
Jens
Post by Jens »
Hi
So i bought em, looks damn nice.
The vtr run fine with the db killers in, np there.
But when i remove the db killers, the problems started. about 4.5-5k rpm it start to run "funny" like it aint getting enouch fule.
So what do i need to do. raise the needel in carb ?. new main jets ?
Any suggestions ?
Jens.
Jens
Re: Leo Vince - need help
Post by Jens »
Just had the sparks out to check, and they look really "white"
Jonesey
Post by Jonesey »
Hey Jens, sounds like it's running a bit lean with baffles out- might need rejet and making a tad richer.
I'm a novice in this area, although I have experimented with about a thousand exhausts.
Cheers mate, Chris.
Defo lean,
get those baffles back in before you take out a valve or two.
I don't know much about the Leo Vince pipes so I can't give you any base settings to start with. If I was you, at the very least I'd get a diagnostic run on a rolling road and see how lean they are or, if you have a little more money to spend, get them to set it up properly for you.
Jens
Post by Jens »
Problem solved :-P
Raised both needels a bit, the front got a new washer in, the rear have to washers in.
Front plug looks fine now :-P
The rear plug is still a bit white, maybe a new jet a bit higher or raise needel a bit more ?
Any suggestions ?
Jens
You need to get it set up (or at least a diagnostic run) on a Dyno, as has been rightly said already.
No point guessing and reading the plugs, you could get main jet lean and pilot rich and plug could read ok, but end up with a burnt piston crown.
