Help!
Giddsy
Help!
Post by Giddsy »
Right another problem... :(
This morning on way to work I noticed that the instrument cluster had died completely, no speedo, tacho or lights (except indicators worked). I was right near work so continued and on pulling up the engine cut out and on turning the key there was absolutely nothing there. I haven't had a chance to check any fuses or anything at all yet.. Any ideas?
Thanks in advance...
James
marlbororman
Re: Help!
Post by marlbororman »
would imagine reg rectifier or the battery has died completely or both.
Jazzscot
Re: Help!
Post by Jazzscot »
marlbororman wrote:would imagine reg rectifier or the battery has died completely or both.
I agree, happened to me same symptoms. new r/r and battery fixed it.
Jazz
Everything good is bad
Everything bad is good
Giddsy
Re: Help!
Post by Giddsy »
Yep battery totally dead... I hope r/r is fine. I had a loose connection recently and that flattened the battery twice so think this may have killed it. It is an R6 r/r and appeared to be working fine once I reconnected it.
Thanks for your help.
James
Soutie
Re: Help!
Post by Soutie »
Had the same happen to mine on the way to work, all of a sudden all the instruments and idiot lights went dead. it turned out to be a loose battery terminal. I just tightened it up and all was well.
