Front CCT and Haynes info ???
Jens
Post by Jens »
So i changed the read CCT. wass np at all. Working on the front cct now.
In the guides on this forum. it says i should turn the engine 1.5 or so until the mark FT alignes.
In the Haynes manual it says the same, but also says that the marks on the crankcase cover should align with the FI and FE marks !!!
I tryed this but cant get em to align at all when the mark are on FT.
any one noticed this before ? and what do i have to work after, the haynes info or the info on this forum ?
Jens
Jazzscot
Re: Front CCT and Haynes info ???
Post by Jazzscot »
You did turn it anti clockwise didnt you??
one and a quarter turns
Everything good is bad
Everything bad is good
Jens
Post by Jens »
yes i turned it anti clockwise.
Jens
Post by Jens »
FORGET my question, i found the problem. i looked again at the rear cct. :redface
Jazzscot
Post by Jazzscot »
To coin a Brittish phrase which may not translate very well.
You Plonker!!!!!!!! :beer:
