100-120 was best on mine (general) I've never had a twin with decent tank range-the buell was by far the best.
Your bike is unbelievable BH-180mph, 180 miles to the tank...
Tank Range
Re: Tank Range
SP1's rock!
Re: Tank Range
You could be right, I've got the bigger tank and even when the last bar is flashing I've never put more than £16 in........ever, and it dont seem like theres loads left in the bottom of the tank!!FirestormMike wrote:Tell you what though, either Honda lie about the tank size (my favourite answer), the gauge lies or reserve is a hell of a lot bigger than you think.
I have never managed to squeeze any more than £16 in, even when the indicator is flashing at me. By my reckoning and todays fuel prices (which are a bit lower than when I ran it right down) leaves 5.1 litres or so. In no way was there that much sloshing around inside when I took a look.
Re: Tank Range
Kinda depends if its just round town or on open road, around town it can go within 6-7 miles but otherwise its around 20-30 miles. But.......when i used it for running over to newport from bristol (28 miles) from full i could use the first 2 bars easily, sometimes 3!!
Re: Tank Range
Yeah, i could only do a return trip and there again before i thought i'd better fill up but it usually only took about £13 but was on last bar
- benny hedges
Re: Tank Range
can't be that far out bud - according to gearing commander calculator thingy, http://www.gearingcommander.com/Timbo wrote:
But as your speedo is way out, ie it reads way higher than the speed you are really doing (storms dont do 180mph)
at the limiter, 10500rpm in 6th gear, standard rear sprocket, -1 on the front, it should read 175mph.
check for yourself - maybe mathematics is innacurate too
if it got to 10500 in 6th with standard gearing, it would top out at 187.
said it won't hit the limiter in top sat up, but tucked in it flies there.
dont forget it has different cams etc to let it rev higher and breathe better... standard it wouldnt hit the redline in 5th & 6th, never mind the limiter.
yours probably wouldn't cos you are like 6 foot 10 and 30 stone
- benny hedges
Re: Tank Range
timbo whats your problem m8, we all know the speedos are out, im not saying my storm does 180mph, i simply stated in another thread that the needle went off the clock when i got behind the fairing lol, with a wind behind me, on a very long private airfield... (more than once)
why do you have to dismiss everything i say as though it's all b/s....
i say ive seen 188 miles before a refill... er i must be lying, because your storm didnt do that!
it cant be right because my speedo is clearly more wrong than everybody elses lol
has nobody else seen 160+ on the clock of a standard storm? course they have.
(whether they were actually doing 160 is another thing)
then isn't it obvious that if you modify a bike so it pulls to 10500rpm it will show a higher speedo reading than one which barely pulls 9k?
maybe gearing commander have miscalculated the circumference of my wheel or something?
maybe i should get another new speedo.
and check my tank holds 19l and not 24
Re: Tank Range
It's not all b/s.
Some of it's baldrocks.
Am I helping at all?
Re: Tank Range
Some?tony.mon wrote:It's not all b/s.
- marlbororman
Re: Tank Range
standard, 2 up with a tankbag brimmed, i managed 167 miles on standard gearing...thats brimmed 16l tank, running out at the pump. taking it very steady.never get anywhere near now mind lol.... that was first weekend out on it. changing gear at low revs too. Ive alsao seen a tad over 160mph on standard gearing, and also had it off the clock on 1 tooth less front 3 up rear, but try keeping front whel on the floor , lol. nowadays im lucky to get 100 miles before the light of death
- storminateacup
Re: Tank Range
I love this forumtony.mon wrote:It's not all b/s.
