hi folks,
well it looks like my rectifier has given up!
just wonderd if the ones on fleabay from hong kong are ok?
or has anyone got an old one lying about?
regards
matt
rectifier caput!
- benny hedges
Re: rectifier caput!
the ones you buy from honda are also probably made in hong kong...
i fitted one off a blackbird (cb1100) and its spot on - look for one with the same plug fitting so you dont have to butcher the wiring.
there's loads that will fit from cb125, cbr400, cbr600. vfr's etc take yer pick,
just bear in mind the delivery time from honk konk if you need the bike on the road...
Who knows ... the Honda ones aren't much really up to much are they .... As a result of the info pick up off of this site I looked at mine. It was a Honda OEM part of the finned variety ... when I checked it was under performing so I've replaced it with another OEM part. I hope this one lasts.
The force is strong with this one!!!
Yamaha XT1200Z Super Tenere
Yamaha FJR1300
Yamaha FJR1300
Got some donated to me by Jonesy at a workshop day in the summer, so you can have one of those if you want for the P+P, unless you want to collect from Sevenoaks, Kent.
Not sure if they're plug'n'play or you need to change the connectors, but even so, not a big job, and I can let you have the pin-outs/wiring diagram.
Crimp connectors will work ok, soldered is better, though.
PM me if you want one.
cheers tony.mon!
it was a r6/r1 unit you sent me,followed the workshop guide on here no probs.
this is a very very usefull site!
thanks for helping me get back on the road.
- VeeTeeArrrrrrr
After my recent Rectum Fryer frazzle I got one from Honky Konky and its fine £10 plus 10pandp, came in a week.
i fitted a finned one from a valerdero 125 and all seems well so far and thats a year ago now,just plug in and go lol.
Darn it, I had to have one replaced last month from Honda. I spent the wrong side of £200. Wish I knew of the cheap alternatives, Was kinda stuck on the road though. RAC man said I was lucky to still have meat and two veg after my Alternator was pumping out 26v into my poor 12v Battery
