To avoid paranoia also fit a voltage display on the dash.
I fitted a combined volts/gear indicator from acumen- the method and wiring instructions are in the Knowledgebase.
That way at least you know if there's a problem, and you can catch it before it takes the battery out.
Re: Voltage
Re: Voltage
- storminateacup
Re: Voltage
You dont need to just ease out the connectors and push them into the old loom.KneeWobblers wrote:Thanks for that but soldering, stripping
, crimping
will cramp my style
, just need advice to what plug in one will work. Blackbird ones????
Re: Voltage
as Storminateacup said, you can fit the R1/R6 reg without cutting stripping & soldering.
All you need to do is :
1) disconnect battery so the wires you are working with wont touch the frame and short out.
2) unplug Honda R/R and throw in bin
3) with small watchmaker screwdriver ease the connecter out of the plastic housing. there is a small barb on the back of the connector, and you push that down from the front [the face that plugs into the reg] with the small screwdriver and gently pull the connector out with pliers on the wire.
4) When you have them all removed, get some heatshrink sleeve and cover the exposed connectors.
5) work out wiring convention of new R/R from the link in workshop section
6) plug in the connectors
7) mount new R/R using 1 of the old bolt holes
use cable ties to bind the harness together and ensure that individual wires wont work loose.
But if you are very, very, very,very, very, very [get the message?], very, very frightened of electrical things, I did post a list of other Honda models which used the newer finned version of the R/R and these will plug and bolt straight in. You should find that on one of the last post in the regulator thread in workshop knowledgebase.
http://www.haymouth.co.uk/phpBB3/viewto ... 30#p143726
- benny hedges
Re: Voltage
i got one off a blackbird.
no not beyonce you tit, a cb1100.
fitted straight on, no fkin about with wires, no more problems.
in fact i didnt have any problems with it anyway, i just changed it as a precaution.
there's loads on ebay that will fit.
just look for same plug connection and bigger / finned.
the ones off cb125 / cm200 / some cbr400 will fit.
if you keep blowing them you need to check out the rest of the wiring, particularly the stator wiring, starter lead, starter solenoid, neutral / earth to frame lead
yamaha r/r aren't bulletproof - on a mate's virago a while ago, the r/r packed up and was stuffing 19v+ into his battery.
or should say batteries cos he went through a few before realising it was the rr lol.
better off with the proper honda one off a later bike imo.
- storminateacup
Re: Voltage
As I remenber there was a locating pip on the connectors that you you need to locate and depress. But careful cutting should do it.KneeWobblers wrote:I have had a go at "easing" the pins out, but they are as stubborn as twenty wives.......I have put a teeny driver in to "ease" them out but cant shift em, would sawing them out be ok, ie with a dremmel type thing.storminateacup wrote:You dont need to just ease out the connectors and push them into the old loom.KneeWobblers wrote:Thanks for that but soldering, stripping
, crimping
will cramp my style
Re: Voltage
When I fitted a replacement rectifier I got all mine out except one, the last one believe it or not. So that was exactly what I did, I cut the white plastic block terminal with a Stanley knife, just don't slip and cut your finger.KneeWobblers wrote: I have had a go at "easing" the pins out, but they are as stubborn as twenty wives.......I have put a teeny driver in to "ease" them out but cant shift em, would sawing them out be ok, ie with a dremmel type thing.
Re: Voltage
I suspect there will be an amputation opportunity hereKneeWobblers wrote:Thanks chaps, going in with rusty stanley now...........................
Re: Voltage
A cable tie would have done temporarily.......
The bolt holes don't both line up anyway, and so at least one is a cable tie, form my experience.
