Cct fitted
chi kung
Cct fitted
Post by chi kung »
I fitted manual ccts today and all seems well but just a couple of questions.
The manual ones I fitted have no rubber end is that ok? Bike runs sweet but just a quick thought as I'm no mechanic.
Thanks to rider on the storm for the bargain ccts and thanks for the instruction in the workshop.
I have been hiding my bike at work in a store cupboard and secretly working on it here and there. It took about 4 hours all in so I would say try it and it's very easy.
Do I need to bed them in or can I start thrashing it now?
Thanks
benny hedges
Re: Cct fitted
Post by benny hedges »
there is no rubber on the end m8 -or on the apes which are more than double what you paid for the TT's and not as good imo.
assuming you've let it run to temp, restarted it & not heard a squeak from the camchain cos it's too tight....
yes, leather it :thumbup:
hope you did those locknuts up good & tight though????
Re: Cct fitted
Thrash it? Is there any other way?
The job's mostly about confidence, and following the Forum instructions to the letter.
But I expect you had the heart-in-mouth moment when you pushed the button.....
Well done :thumbup:
Re: Cct fitted
Benny is right, no rubber end on the manual CCT's.
You may find a fine adjustment is needed after giving the bike it's first run, but if you don't hear any rattling, or squeaks when starting then you should be fine.
Well done :thumbup:
chi kung
Cct fitted
Post by chi kung »
Thanks guys. Ran it up to temp today ( after putting the fuel pipes on the right way) it sounds sweet. Wen the snow goes il give it a thrashing.
Thanks
