As the title suggests. Its probably a silly question but its a simple one to answer. A yes or no is all I need.
I've a completly standard Storm and will be doing it up to my tastes. I will be getting braided hoses at some point and I know I'll need to bleed the clutch and brake lines for that.
I will also be fitting new levers on the clutch and brake so will I need to bleed them too or is it just a case of swapping the lever without draining the resivoirs?
Probably a silly question
- benny hedges
Re: Probably a silly question
you dont need to bleed the brakes / clutch to fit new levers, but obviously you do when you replaced the lines.
Thats what I thought. The chances are I'll be getting one at a time, levers then hoses. Just didnt want to have to go through the bleeding process only to discover I had to do it again to fit the levers.benny hedges wrote:you dont need to bleed the brakes / clutch to fit new levers, but obviously you do when you replaced the lines.
