As per title, I have a new Chain & sprocket kit on the way and will need the tool to join the chain up.
No huge rush as I am off to China for 2 weeks with work and dont plan to do the job till I get back, but apprciate being able to borrow one if possible.
If local to West Midlands I could collect, if not I am happy to pay postage and beer tokens.
Thnaks
Need to borrow a chain rivet tool
You can borrow mine in in Bedford.
Re: Need to borrow a chain rivet tool
Rivet it off the bike at your leisure - then remove the left footpeg and slide the chain in past the swingarm
easier than faffing about under the bike
I've got a Whale HD rivetter you can borrow as well but I'm a wee bit further down the road
@ wicky you serous? its that easy
I want to fit a chain and sprockets to my storm but have been delaying due to not having a rivet tool.
Yes, it's that easy.
Although the rivet tool makes it easier, personally I find it much easier to rivet the chain up on the workbench and if you're going to be fitting sprockets as well you already have tools out and it's a good chance to check and grease the shock linkage too.
Good tip, I had spotted that the Firestorm has no lower frame and that the chain could come off in one if you remove the lower foot rest mounting bolt, but didnt put 2 and 2 together and think how much easier it would be to do the rivetting on the bench.Wicky wrote:Rivet it off the bike at your leisure - then remove the left footpeg and slide the chain in past the swingarmeasier than faffing about under the bike
Tony, I did the linkage before the winter so dont need to grease that again, but good tip for anybody who is doing a chain and hasnt already had the needle bearings out.
Chi Kung, Yes I might take you up on the loan if nobody in West Mids comes up. can you guestimate postage based on the weight?
And cheers the vacuum adapter arrived today - Had me puzzled as I couldn't remember ordering a vacuum pipe amongst all my clutch bits 'n' bobs but eureka when I saw the adapter.
Yes I did disguise the adapter by putting it in the pipe!Wicky wrote:And cheers the vacuum adapter arrived today - Had me puzzled as I couldn't remember ordering a vacuum pipe amongst all my clutch bits 'n' bobs but eureka when I saw the adapter.
