Tight Spot
Bink
Tight Spot
Post by Bink »
Anybody know how to get rid of a tight spot in an X-ring chain?
The chain has only been on the bike for 4000mls and has a tight spot in it which causes annouying vibrations on the left hand side of the bike.
mercury
Post by mercury »
Try clean with paraffin set tight spot corect tension
lite lub once a week and keep clean with paraffin
if you do this should get 15k miles from chain
So thats why i bought a bike so i could see my money and licence go quicker
Bink
Post by Bink »
Just a thought ...
Would it help if I turn the chain over? As it will bend over the other way it might loosen up the tight spot ... or possibly make it worse ...
Any bright sparks out there who can help?
Otherwise I will have to get the wallet out and buy a new chain & sprocket set. :( (after 4k mls)
