r/r query
- uptonpark64
r/r query
after reading some of the letters posted, i bought a r1 r/r of ebay and today decided to change it, but after taking the fairing off i found a finned r/r already on, is this the normal r/r or did the previous owner change it already? its got no serial number just "tour max- high performance equipment" on it, also, is there anyway of knowing if they changed the cct on it for a manual one?
Re: r/r query
is the one on the bike not working as it should ?
dont fix whats not broken !!!!
- uptonpark64
Re: r/r query
if you read the forum, most people say change the honda one, their shite
Re: r/r query
Re. R/R On the back or bottom should be a serial no beginning in SH (shindengen) - I believe that is OEM - IS your storm pre2000 or a later model? The main thing is that it isn't an unfinned fryable one.
Search and ye shall find: CCT ID > http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=18479
Re: r/r query
new Storms had a finned part which is much better than the old version [but should be a Honda part no], or previous owner added an aftermarket part which fits the honda connector. you should be OK without changing it
- uptonpark64
Re: r/r query
thanks for that, i'll leave it alone then..... anybody need a r1 r/r!!!!AMCQ46 wrote:new Storms had a finned part which is much better than the old version [but should be a Honda part no], or previous owner added an aftermarket part which fits the honda connector. you should be OK without changing it
Re: r/r query
i might do how much do you want posted ?
Re: r/r query
lloydiecbr wrote:i might do how much do you want posted ?
dont fix hats not broken
Re: r/r query
i hord spares i cant help it you never know when you may need them
- benny hedges
Re: r/r query
mine was working fine but i changed it anyway before it failed on me & cooked my battery in the middle of nowhere.lloydiecbr wrote:is the one on the bike not working as it should ?
& you cant say that about the tensioners... you dont want to wait til they break!
if its a known fault and yours hasnt been done, get it sorted.
keep the old one as spare... you might be able to pull someone out the sh1t with it if theirs goes.
or you could just say i told you so
Re: r/r query
the mcct are a must .
but the r/r i would of checked it first to see if it been uprated . i will be picking my 1st firestorm on tuesday and i will have a good check over it for any niggles bogges or anything on its way out
- uptonpark64
Re: r/r query
check yours when you get it and if you do need one, let me know, i live just outside leamington so no need to post, i'll meet you someplacelloydiecbr wrote:the mcct are a must .
Re: r/r query
sounds good mate
