Throttle grip - lubricate?
- bandsawman
I've got my throttle grip off and I've cleaned it all out - does it go back together dry, or should it be lubricated, and if so, what lube?
Going anywhere in a car is a journey, going anywhere on a bike is an adventure!
Re: Throttle grip - lubricate?
not sure if it needs lubing, cant remember from when i changed mine a few year back....if you do i would recommend booty lube from ann summers
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
Carbon Hugger
Carbon undertray
Harris RearSets
Proflex suspension
- bandsawman
Oh behave! (said in an Austen Powers style)bigrich wrote:not sure if it needs lubing, cant remember from when i changed mine a few year back....if you do i would recommend booty lube from ann summers
silicon spray i use on the tube and cables works very well
- bandsawman
Ok, I've now used silicon spray on the tube, but a bit of grease on the cable ends and along the last couple of inches. Seems pretty good.
