Front Sprocket Bolt!
Walenut
Post by Walenut »
Just changing my chain & sprockets is it a normal right hand thread or a left hand thread on the front sprocket?
Due to cutbacks the light at the end of the tunnel has been switched off!
Walenut
Re: Front Sprocket Bolt!
Post by Walenut »
Ah just found it. Anticlockwise, really don't want to snap that one off. 8O
benny hedges
Post by benny hedges »
as a rule the sprocket nut will tighten in the opposite direction of rotation so it doesnt come loose while riding.
this is why they're very often near impossible to shift with hand tools!
benny hedges
you could ride it to a hvg tyre place, whip the casing off and ask them to spin it off with a big windy gun.
much better option than standing on a bar or bashing it off
Walenut
Post by Walenut »
Its off with the aid of my big breaker bar. :thumbup:
bigrich
Post by bigrich »
i just sat on the bike with a rachet and pulled the fecker ! worked for me!
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
You can jam the teeth on the sprocket against the swing arm casting with a combination spanner, about 13mm I think.
That stops it turning and you can then undo it with a 1/2" socket.
God, I'm a bodger, some days.......
