Hi guys
I'd be interested to read your experiences with EBC front discs on the VTR.
I fitted a pair around 12000 miles ago - the Honda discs lasted 32000 miles but as they cost about £250 each I went for the EBC solution.
Recently I noticed the dreaded judder on braking, so I had a close look at the bobbins to see if they had seized due the salt.
I noticed one of the rotors was not aligned with the carrier which explained the long lever travel and juddering.
I had a probe around and just under half a belleville spring washer dropped out from one of the bobbins!! I inspected this and it looks as if this had been cracked for some time.
The remainder of the washer is still in place so as long as the disc runs true it should be OK. the rest of the bobbins/washers are OK
Maybe its not a cheap fix after all - 12000/32000 = nearly one third the life of a genuine part.
Any similar experiences?
EBC Front Discs
Re: EBC Front Discs
I bought OEM replacements from DaveSilvers at about 35,000 now on 50,000 still going strong...
- benny hedges
Re: EBC Front Discs
i think maybe you should contact ebc and explain whats happened....13yearsVTRrider wrote:
they may say thats fair usage but imo you would expect better from a reputable name.
keep us informed
Re: EBC Front Discs
The thought had crossed my mind Benny - I think I'll get on and do it - no feedback = no improvement! Cheers.
Re: EBC Front Discs
The wheels are in motion with EBC . Next instalment soon.
Re: EBC Front Discs
Would you believe a 12 month/12000 mile warranty on EBC brake discs?
I contacted Fowlers in Bristol ( my locality) - £119 each plus vat. No contest!
Good for Honda.
While I was at Fowlers getting some bits, I sidled over to the bike showroom and had a look at a KTM RC8 ( and sat on one - brought a smile to my face) Trouble is - an 1190cc sports bike with a 16.5litre fuel tank giving a range of anything between 80 and 140 miles.
I am currently getting 160 plus miles before refuelling which leaves about 2.5litres in the tank- albeit cruising up the M5 at 4500rpm and not winding on at every available opportunity - it usually takes 16.5 litres to fill it up again - although one time I got 17.6 litres in. Mind you I am using it for commuting.
