What is the point of changing a sprocket?
I've often wondered about this. They way I see it, say you wanted better acceleration then you would put on a smaller front (or bigger rear). This would then have the same effect as throwing away your 6th gear and giving you a shorter gear before 1st, i.e. the only difference is in your new first gear which you use for maybe a second. Doesn't seem worth it.
What am I missing?
(I doubt that going the other way for increased top speed would work either as you just wouldn't have the power in the 'new 7th gear').
What am I missing?
The only thing that I can say on this is... it is worth it!!
I have fitted a 15 t front and the bike is transformed, it pulls cleaner through all of the gears, it picks up better when in a higher gear and is an absolute blast to ride, it pulls out of corners like a demented rhino all for the sum of £19 and about 10 mins work.
Out of all the mods I have done to my storm this is by far the best and most significant improvement to it.
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."
- Stormin Ben
Physics lesson warning
Its all to do with torque, which is force times distance from pivot its applied
The force from the engine stays the same but the bigger rear sprocket means that more torque is applied to the rear wheel
Basically changing sprocket is not as drastic as the jump between gears. Think of 2nd gear being more useable and you're getting close.
The difference is only about 7% so if you're in 2nd on a stock bike and its doing 3000 revs, with a 15t front it'll be doing 3200.
Doesn't sound like much but that difference could be 4-5 horsepower. Which you would notice
Ben
Ben
- STEVESTORM
bottom line..
I have just done 15 t front and 45 rear. The bike will now outrun anything!!!. Tops out at 120 and revs higher but fun is infinite - total cost (DIY) £ 160 incl 2 x sprockets plus DID Heavy chain
- Stormin Ben
You can get a 2 tooth bigger rear on with the standard length chain.
Plus points: Shortens the wheelbase so it turns better and wheelies easier (or would if I was any good!!)
Negatives: Standard road tyres are fine but I've had 2 sets of track tyres that wouldn't fit with the hugger (208GP's and Rennsports)
15tooth front is also fine with standard chain
Plus points: cheaper than a rear sprocket
Negatives: Lengthens wheelbase so opposite of above. 15t is getting a bit small for a chain to go round comfortably. Its not gonna kill it but it could reduce the life due to the fact its having to turn a sharper radius corner
Ben
Ben
- Fireman on a Storm
- Stormin Ben
- STEVESTORM
After fitting a 15t front and 45 rear I have used a 104 link X-Ring DID professional chain. The standard chain will accomodate 1 tooth change on the front or 2 on the rear. If you change both sprockets or go to a 45 rear then you will need a 104. It's always best to change sprockets and chains at the same time.
B+C express do Renthals in anodised bronze which looks good with gold chain.
Warning / Advice - My bike is now a 15 / 45 instead of stock 16 / 41. It is now 30mph short top end but will out accelerate anything including my mates ZX12R.
Its fun and short / medium journeys are spectacular but long distance isn't funny.
