I did manage to get her running but was a running like a bag of nails. Before being put away for the winter I decided to give the old girl a bit of a service. New spark plugs, new oil and filters.....after all that, it ran like a dream. Only thing I didnt do is a coolant change becasue it had recently been done (all I did was top up with coolant). So was expecting it to start fairly easily with a gentle of a poke and prod.
The fuel that was in it was from whenever so topped up with new fuel. Tried again and was only firing on one cylinder. Checked all my fuel hoses that I had disconnected for the respray to find one of the hoses was not quite on properly, pushed it back on and it seemed to want to run again, but, would only run on full choke. As soon as I put the choke in it would die. Started her up again (on full choke) twisted the throttle and died. By this time its getting dark and so was quite ready to give the bike a Peoples Elbow or a Hulk Hogan style Leg Drop (neither of which happened because the paint is too good looking to damage lol). Anyway, I havent yet pulled the plugs to check for spark or done much else.....thought I would come on here to ask for advice and see if there is anything in particular to look out for on these before I start going mental. Before you ask, the reg has been swapped for a finned type jobby, but, not ruling it out until I put a tester across it
HELP!!
