guess you've taken on board the lessons learnt (the hard way) but mind you don't drop those little feckers down the hole! It can sometimes be useful to jam a snot load of grease up the socket - holds the bolt in place whilst withdrawing. Plenty of paper towelling/ rag stuffed into open holes has saved my butt a few times too!tony.mon wrote: undo small bolts inside the camchain tunnel first, then all of the head bolts.
Just recently lost a CCT on the front cylinder of my Storm and I feel your pain. I count myself very lucky to have got away with no damage but dropped the head off to be sure. Absolutely hate performing "open heart surgery" in situ, the luxury of a nice clean work bench is preferable but hey, needs must.
and I'm too bloody old for crawling around on my knees! What I wouldn't give for one of them hydraulic lifty jobbies....
There was a cheap engine on Fleabay in Cambridge that had headgasket problem on rear cylinder - might be good source of valves/ pistons or whatever? Dunno how close that is to you....
Any hoo - good luck, hope the damage is not too bad.
Bart
