my plug cap has failed 120mls from home,is it possable to bypass the cap by running a wire from the ht lead into the cap so it connects to the plug or is there too much power coming from the coil to do this
andi
quick fix needed
Re: quick fix needed
run it on one to get you home ,
You could try any spare plug cap, break off the insulation which will leave you with the metal connector and the bit that connects to the top of the plug.
Even a 90 degree one could be straightened.
Obviously plenty of insulating tape to stop it earthing out, but as long as it's not raining it should get you home.
thanks for the advice lads...it turned out to be the coil that was breaking down...luckily i have some spare ones and managed to txt bro inlaw to pick me up so i could get one...stupid little breakdown cost me £100 tho....lesson learnt---next time it misses even slightly,check it out straight away.
