Bit of guidance please
Re: Bit of guidance please
pm sent(belly pan)
Still available pick up only!
"When one person suffers from a delusion it is called insanity; when many people suffer from a delusion it is called religion."
i have the same bellypan fitted to my storm and it cracked it the same place due to the stand coming up hard...i recommend you get some thin foam from the craft shop and some double sided sticky tape....you can't get the pan on without scratching it uless you use a paddock stand stood on two pieces of 1/2inch wood strips to raise it enough to twist it round the sidestand then under the bike....after you get the bellypan fitted cut 3-4 small squares from the foam and stick them together,then lift the sidestand up and look to see where it lands and stick the foam in place..this takes the shock out of the stand hitting the bellypan...also put some fibregass on the inside surface where the stand hits to strengthen it too.
andi.
andi.
Good advice Andi
Top tip, the insurance companies like to charge a silly extra premium for after market belly pans, if you are honest they will add cash, if you are not they can be easily removed and thrown over a hedge before plod/ins assessor sees the bike. Up to you, I paid a bit extra but stupidly the zorsts were a free add on.....go figure
Its a fookin lottery mate, you never know what will happen
Glad you got a good deal, I think that info was from Bennetts. I am with Adrian Flux now.
