Over the winter I took time to rebuild the forks on my ,98 Storm. Replaced springs with Hagon units, fitted new inner and outer bushes, rebuilt as per the manual and there is a (small) clonk on full compression. Is this normal or is there something else I should check? The head bearings were checked, re-greased and adjusted at the same time.
Pop H
