Wheel bearing part Numbers?
I have had a search, and a look in the Haynes manual, but can find the serial numbers for the wheel bearings [ie 6004 2RS C2, [size, seal type, internal clearance grade]].
Anybody got those numbers for the front & rear?
benny hedges
Re: Wheel bearing part Numbers?
Post by benny hedges »
they will be a c2 bearing, not sure what the DDU means but they do have 2 rubber seals so the 2rs is right
the part for the front is 6004 2RS DDU 20x42x12 - 42od x20id x12mm wide
the part for the rear is 6204 2RS DDU 20x47x14 - 47 od x 20 id x 14mm wide
kyoto info - Kyoto Motorcycle Bearings
High strength AISI 52100 chrome steel in all inner rings, outer rings, and rolling elements, heat-treated to 60-65 HRC.
Manufactured to ABEC 1 dimensional tolerances.
Every Kyoto Bearing is electronically tested for noise and vibration according to ANSI/AFBMA Standard 13-1987.
Factory-packed with premium greases like CHEVRON SRI-2 and MOBIL POLYREX EM
Quality control system complies with the international standard ISO 9002, 2000 and its technical equivalent,
all the info is from wemoto , just click i next to the part :Beer Popcorn:
never thought to look there :lol:
DDU is a designation for a full contact seal, thought it was the SKF naming, but I should be able to source some through my contacts. thanks
A couple of folk on here have mentioned ceramic bearings. Are they available readily over here and are they better than stock?
What do you reckon chaps.
