wanda101 wrote: I know the tap i bought last year did not come with an O ring and so I can possibly assume it was not replaced with the tap.
that will defo be the problem.
you may be able to fix it without buying a new one by removing the old seal, boiling it in water to clean and soften it, then seal round it with blue hylomar.
either that or cut a rubber gasket to fil.
dead easy.
where are you from btw????
if you're near someone they will help you out rather than pay a mechanic who seems keen to rip you off.
is the 'yous' a scouse thing, if so ride it down here at wkend... im in warrington
