Help - anyone in London...
RQ
Post by RQ »
Ah jeez Pete, I was reading it after posting the message and was thinking "naah, nobody will pick up on that one........." How wrong was I. It only took you didn't it!! 8O
RQ.
The Stig of 2 wheels as well as 4 !
Hee HeeHee :lol:
Could'nt resist.
First the b8stard server went splat andthen some tw@ in a digger chopped our Broadband line so I've been logging in on slimband from another office when no ones about. It's been driving me crazy :twisted:
So I have'nt been able to join in as much as usual.
Still not fixed, but you made me do it :P
delmeekc
Post by delmeekc »
m666
you fixed it yet or dya want me to have a prod
8O
del.
RQ
Post by RQ »
Go on Pete, "Prod"? You can hardly let that go too.
RQ.
Bugger!
Slipped of home early as usualand Missed that one.
Oh well maybe next time :wink:
Dels right though. we are messing on muffins little post
Whats the status me boy. I'm feeling a little more sensible today :wink:
Go on...let Del give you a prod :D
Muffin666
Post by Muffin666 »
Guys,
looks like it's electrical after all - took it down to a see a friend of a friend and straight away he said it was plugs, caps or coil - or any combination of the above.
Apparently one of the four plugs (never realised this was a twin-spark engine...) is very difficult to get at to change. Any of you guys done it before? Any hints or tips (like: let a mechanic do it, you berk!)?
M666
RQ
Post by RQ »
T-spark????????? I've only two on mine in total. Don't I???? 8O
Simple enough job to do, rear one harder to get at, just unbolt the tank and tilt it enough to get at the plug.
Are you sure you heard him right, 4 plugs??
RQ.
EggShellBlond
Post by EggShellBlond »
Yeah , 4 plugs
Look from the LHS , see 2
Look from the RHS , see 2
So that's 4 :roll:
If a job's worth doing..........It's worth paying someone to do it properly
delmeekc
Post by delmeekc »
So it has 4 wheels too then :?
EggShellBlond
Nah..........
Keep yor eye on the wheel as you walk round , you'll see its the same , but viewed from a differant angle
HTH :wink:
Bin thinking a bit about this one now.
1st Are you sure it's a Storm? (4 plugs 8O )
2nd If it is, Could the TPS be up the swany?
It would run like shite at low revs if it was. A quick check is to run the bike at 4000 rpm and remove the sensor plug (righthand side the carb as you sit on it). The revs will increase if its working. If no change it could be a suspect.
Only an idea but it's easy to check and might eliminate something from the list
Muffin666
Post by Muffin666 »
S*dding mechanics... I was surprised by his suggestion that there were four, so I had a quick look last night and unless there's three at the back, there's definitely only two of the buggers. Why don't mechanics ever tell the truth? Or are they just stupid?
Well, I'm finally taking the plunge and getting my hands dirty this weekend (after promising to do so for the last couple of weeks) so hopefully I will be able to tell you all in the next couple of days that all is well... New plugs and caps, clean and oil the air filter, and I'm going to have a look at the fuel lines which can, according to some of you guys, get squashed or twisted under the tank
Pete.L. - ta for the tip - will try that too.
Fingers crossed.
Muffin666 :evil:
Bink
Post by Bink »
Still a bit confused here ... :?
Why are you doing all the work and paying for the parts ???? If the bike runs like an asthmatic through a freshly cut meadow it's the dealer who needs to fix it not you!
Or is it just that you can't be bothered with the agro? 8O
delmeekc
Post by delmeekc »
Mate,
if you want me to ak a look then it maybe worth it cos I have coils, tps, cdi etc complete loom, balance gauges, pilot air screw tool, and hot cups of tea too. and good rates
Del.
RQ
Post by RQ »
I know who I'd bring it to. I've read the cuppas are great too. :wink:
RQ.
