http://img.villagephotos.com/imageview.aspx?i=27314759
Inlet Rubber
Inlet Rubber
Some say this is a restrictor But I think it's an attempt to smooth out low speed throttling.Anyone Sure?
Re: Inlet Rubber
Mine don't look like that and if they did I would take it out! That is far too restrictive, and must be having an effect on max airflow.
I think it is normal to have a thin steel insert in there, but it should only just be visible, and the 33 hp restrictors i have seen for sale are concentric, so what you are showing is a 1/2 way house. But as i said, it will be restricting top end. What age and spec bike is it off?
Re: Inlet Rubber
Is the bike an import model
Re: Inlet Rubber
Someone online said some bikes come fitted with them whilst others don't ,no matter what country.Maybe someone on this site Knows.
Re: Inlet Rubber
Can't see the picture, but it sounds like the steel insert has pulled part way out.
Just remove it, although it's designed to smooth low speed /revs airflow, it doesn't do anything noticeable.
If it's any form of restrictor, you'r better off without it.
Or just buy or borrow another set, and try them.
- benny hedges
Re: Inlet Rubber
is that pic off an older carbed varadero???
i had ally discs in my carb rubbers which i tugged out obviously but they werent as deep cut as that.
what year bike is it?
this is what mine looked like - off a uk 2001 model
