KPH to MPH clocks
slightly despy newby
KPH to MPH clocks
Post by slightly despy newby »
One problem solved (thank you both) but like Columbo used to say...'just one more thing' .....
I have bought some analogue MPH clocks for my 1998 stormer....it did have KPH clocks....can I just swap them over or do I need to change the sensor on the carbs over too?
benny hedges
Re: KPH to MPH clocks
Post by benny hedges »
same item bud, just a different face on the speedo and odo measures in km.
afaik the speed sensor is same kmh or mph
So i'm good to go then :thumbup:
Yes, direct swap.
Trigger is the same for all models, also fits several other models across Honda's range.
This is getting better by the post :D and a sht load better than working on my Vmax....thanks guys
