was playing about with the shock yesterday. I fitted the wee spacer thing under the top mounting point. I loosened the preload adjustment down one notch using a wee chisel and a hammer. And it moved no problem. I then tried to move it back up a notch to the original setting but it ain't happening. Are there any tips in doing this.
If I was to get a C spanner what size would I need for the shock?
Also noticed that once I fitted the spacer the lower suspension looks very close to the exhaust header, not sure if it was as close before spacer was in. How much of a gap is normal?
Cheers in advance Jazz
Shock adjusting C spanner
Everything good is bad
Everything bad is good
Re: Shock adjusting C spanner
After fitting a spacer you will find the chain will need tightening a bit but all should clear the exhaust. When adjusting the shock i'ts better with no weight on the back wheel . That means either an Abba type stand or a block of wood under the sump.I like to keep the shock collar lubed up with sillycoon spray or WD40,a Vtr tool kit with the propper C spanner can be had on Ebay not much more than a tenner
Theres A Hare in The Turnips.
- chris vtr virgin
Jazzscot hi its chris vtr virgin from dunfermline i met you at the lizzy on a thursday night a while back i have the blue storm .
Anyway i have the c spanner in the supplied tool kit from honda if you need a borrow of it.
If you need it just send a pm with your number and i will get it to you.
cheers chris.
cheers chris.
Some twins have all the fun !!!!
Good lad Chris my man I appreciate that. Do you know what size it is??? Have you got those cct's done yet?
Jazz
Jazz
- chris vtr virgin
Hi jazz will have a look tonight at size
of spanner
or i could meet u kirkcaldy b and q at 7 the night
Oh still not got round to doing ccts but will be soon
of spanner
cheers mate. Im no desperate for the spanner as Im sure I could maybe get her on the abba stand and have another go with the hammer type tool
Im just interested in the size of the spanner thingy just in case I need to get one of of eblag, but as I know you just along the road with one its cool.
Jazz
Jazz
