My son has got a cg125 that has a scratched cylinder. It is a 2002 model and I was wondering if older cylinders would fit.
There is one that looks exactly the same but it doesn't say if its from an older model?? http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_949
Anybody on here have any knowledge of such things.
Cheers Jazz
Son's CG 125
Son's CG 125
Everything good is bad
Everything bad is good
Re: Son's CG 125
ny nephew ran a GC125 for 3 years and it was a rolling repiar with bits from every vintage getting put on it as the base bike failed.
From what he was doing he put any year parts on it, engine or bodywork. the engine seemed to work what ever vintage, the bodywork was another story!
he didnt research much, he just picked up buts as they came available and fitted / modified them to keep it running.........it did look like something out of scrapheap challange at the end, but was alwas running!
- benny hedges
Re: Son's CG 125
have you thought of putting a 150 kit on it????
if it is the pushrod engine (no cct) you can fit these. http://www.ebay.co.uk/itm/NEW-BIG-BORE- ... 1768wt_686
note you will have to take a grinder to the bottom of the liner to get it to fit the crankcase.
(some say it cant be done.... pfffft)
or, regardless of pushrod or camchain model, take a look at this site for some more options... you can take it upto 213cc with a bit of work.
easiest option is bore it out 3mm and fit a cb550 piston, but check the gudgeon pin diameter before deciding what to fit.
also note, you may have to trim a bit off the piston skirt, but the bonus is, the barrel will still be stamped up 124cc
Re: Son's CG 125
he is just about to turn 17 mate and I would prefer him to stick to the 125cc just now. So im taking it basically any cg125 cylinder would fit it?
edit**** Benny just read this on the link you sent me ----------The barrel (M and ES) (2001 onwards) has an oil way in the base, so you can not use an early barrel on these later engines.
Also the cylinder head has a different shape combustion chamber and will not fit on early models as the domed piston will hit the cylinder head.
cheers mate.
Yeah its a pushrod engine Benny and if I had my way Id go down your preferred engine route and then cafe racer it.
Jazz
cheers mate.
Jazz
- benny hedges
Re: Son's CG 125
read that article linked to at the end... apparently some older pots wont go on cos of different oilways on certain models.
can you not just rebore it???
Re: Son's CG 125
benny hedges wrote:read that article linked to at the end... apparently some older pots wont go on cos of different oilways on certain models.
Its got quite a few deep scores on it, I wonder how far they can be rebored?
An Engineering company up her quoted me 40 quid for a rebore and then I would need to get a piston again he reckoned 35-40 quid.
dunno if these guys are worth a shout> http://www.gtowers-motorcycles.co.uk/rebores.htm
- benny hedges
Re: Son's CG 125
40 for a rebore on a single seems a little excessive to say the least!!!
i think you need to shop around m8!
