R1 Mirrors
R1 Mirrors
I'm sure I've read on here somewhere that R1 mirrors are compatible for transplant onto the storm and far better as they stick out further....which years are compatible????????
Re: R1 Mirrors
As the site's own search doesn't do any search for 3 & less characters then use google's site search for the terms:
http://www.google.co.uk/sitesearch/ and enter as the site URL
then search for:
R1 mirrors
Code: Select all
http://www.haymouth.co.uk/phpBB3/
R1 mirrors
Re: R1 Mirrors
Yes they do fit.jono49 wrote:I'm sure I've read on here somewhere that R1 mirrors are compatible for transplant onto the storm and far better as they stick out further....which years are compatible????????
I've just got a pair myself.
They sit lower due to the angle of the arms, you do get a better view however. TBH I havent tried them out yet, only fitted yesterday so I cant comment on weather they wobble about or not. I can comment on the fact that the Yam rubber boots don't look quite right as they are a different shape.
As for which year, apparently mirrors are fairly universal, but to be on the safe side either take your bike & some spanners, or just a mirror or do what I did. Take a mirror off, use a thick marker pen & apply some ink to the bolt ends & press onto a piece of paper to mark the distance between bolts. Take that to a breakers & compare.
Re: R1 Mirrors
i think the hole centres are either 27 or 30mm..
Re: R1 Mirrors
Had a pair on for over a year now a lot better rear vision well worth it if being safe is your main need dont look to bad at all .
Plus have found that if your bike is knocked over by a tw@ in a car they provide good crash protection
Re: R1 Mirrors
Can you remember what year of R1 they were from?balls wrote:Had a pair on for over a year now a lot better rear vision well worth it if being safe is your main need dont look to bad at all .
