Thanks Pariah
Just tried it out this morning after finishing it last night, I have found the best way is put the Rear paddock stand under to lift it, slide the abba type under and assemble and tighten the screw, then gently lower the paddock stand and grip the belt on the seat and gentle let it roll forward until it rests on stands own legs! I removed the belly pan and put my trolly jack under the sump and it lifted the front nicely and spot on for a tyre change etc! when I do the tyre change I'll post some piccies then
