I am using a piece of 18mm mdf as the base, and florist foam to create the shape (£13 for 10 blocks off ebay witht the 2.5ltr fibreglass kit at £25-30
It's possible to use expanding foam from a can and may be stronger that florist foam
Once the base has been shaped the foam can be stuck on
I used a can of spray glue, however it takes too long to dry. There must be a better glue
Any suggestions for a quick dry glue?
The florist foam is easy to cut with a bread knife.............
.............and sanding is a doddle using 60 or 80 grade. Really nice material to work with
Once the basic shape has been formed it's back on to the frame to have a look
It's much better to have the tank in place, however it's away at the powdercoaters
They have had a few setbacks so I don't have it at the moment
Bit more sanding and shortening and back onto the frame
You will notice on the sides that there is some foam missing
Once the final shape has been sorted, any holes and mistakes can be filled
Will leave it at that and wait for the tank (hopefully Wednesday)
I can then create the final shape and begin the fibreglass process
Hope you find this interesting
