Hi all,
I keep reading about CCT failure's. Who's had 1 go and at what mileage? My storm has done 19000 and as far i as know it's not had 1 let go yet. Got the bike second hand with 8500 on the clock. Had a look at the service reports and there's nothing in them to say it's had a problem.
CCT FAILURE and at what mileage
Better to burn out than just fade away!
- tony.wilde1
ccts
if you do a search on here for all the posts on cct's youll find loads of different milages and reasons///...only one fact..if the spring goes your engine will be toast!!and ..its only the spring that goes ok?basically if your worried change them for new ones..or mod them as some have done on the forum!cheers egg.
- tony.wilde1
springs
i dont think you can buy just the springs..the whole 2 units cost £67 a pair from dave silver...plus 5 hours fitting approx.
- Pete.L
Bloody Hell
Tony Said
Are you changing the tensioners or giving a full service (shims ect) as well
Tony Said
You must have a slow tool kitPosted: Sun Oct 31, 2004 12:20 am Post subject: springs
- tony.wilde1
tool kit
yes it is slow..kneeling on block pavers freezing me nuts off!!eeeeeeeeek!
