thumperslaw wrote:benny hedges wrote:Yeh swap it of you have a spare part. Just in case the broken bit vibrates out and falls down the tunnel.
What you doing with the old engine btw... I need some bits for mine...
What do you need
well i have a set of +0.5mm 11.5:1 pistons so am not bothered about the wear in the bores but when the chain broke on mine it took out the mounting lugs for the clutch slave & sprocket cover...
i dont fancy doing all the work on an engine thats been botched, plus the selector drum is on its way after years of clutchless changes and abuse...
i do have another set of casings but on close inspection, the boss that holds the advance gear is cracked with a piece missing...
i could weld it & remachine it, but again, it seems a lot of fkin about & i'd rather not use an engine that's been repaired as a base for my rebuild.
so yeh... whatever i can lay my hands on. cheap! basically a complete engine but i dont need the heads or starter, starter gear, flywheel etc.
the completed mill will have the oversize hc pistons, with new rings, i'll go a bit further with the head porting, fit the extreme cams ive already got and replace all the internal bearings & seals, finished off with a nice new shiny barnet clutch kit
should be worth the effort.
bodywork - most of the frame is already stripped bare... not sure yet whether to powder coat it all in black or polish it up.
im keeping the white but will most probably be fitting the fibreglas race fairing & seat with my pyramid belly.
might not bother with lights. see what happens.
if i do i'll be fitting a projector set off a gilera ped (already got) - the lamp its got on atm is fkt tbh & not worth a fiddler anyway, but i rarely ride it in the dark so dont really need it.
got a new gold xring chain & sprocket set with 15/44 cogs, new cush rubbers, new set of racetecs ready to go on but will be stripping the wheels and coating them black as i cba with the white.
just short of a rear hugger as mine is smashed to buggery off the chain....& undertray as the std one is wrecked but i'll most probably glass one meself to suit the single seat.
no rush with it as ive got the sp to ride, but i'd like it all done by easter obviously
