Had some gaskets on order from Dave silvers for a good while now, status shows awaiting back order still
promised me they would be here yesterday, contacted them today and now its early next week sometime.
Are they needed or will the exhaust be ok with out them? will it blow badly? damage the head etc?
Cant be arsed with the train to work toning.
Exhaust port gasket required?
Re: Exhaust port gasket required?
if you still have the old one, wrap in in tin foil and re use it. if it blows then replace it when the new parts come, if not just kee it.
if you dont still have the old ones, then I dont think it is a good idea to try and fit without. from memory, they are about 5mm thick, and you would cause problems trying to take out that slack.
dont have the originalsAMCQ46 wrote:if you still have the old one, wrap in in tin foil and re use it. if it blows then replace it when the new parts come, if not just kee it.
i did buy some a while ago but lost them somewhere in the garage and have not been able to find them, dam it
The OEM honda ones are crushable copper rings, and are best worth waiting for.
