klunky gear box
klunky gear box
does any body have a bad clunk going into first and second?
clunky gearbox
I think you'll find thats pretty much the norm as the selector forks have more movement between 1st & 2nd
- Fireman on a Storm
Clunky 1st/2nd changes are a Honda feature (undocumented and unacknowledged, of course, except by owners), and the VTR is almost as bad at it as the VT750.
There are several ways to deal with it: the first (and most expensive) is to have your gearbox dogs machined, and get a shifter kit. If - like most of us - you can't afford that, then short-shift at low revs into second, or else don't change until the revs are high, and keep the power on as much as possible. Preloading the gearlever (applying pressure before you shift) also helps, as can doing clutchless changes.
Other things you can do to help avoid the clunks are lower the gearing and avoid using first gear (or short-shift), and keep the chain adjusted and well-lubed.
If you're really unhappy about the clunking, buy a Suzuki - apparently they have good gearchanges (?) Dunno - I've owned 6 Hondas, and that's all...
- Ian in EnZed
(Red 97 FireStorm with Dynojet kit, APE camchain tensioners, bafflectomy+ploogs, UniFilter, GenMar risers, Avon Azaros, 90/130W headlight, digital clock/voltmeter), Braided s/steel lines.
Kerlunk
Try using semi synthetic oil. I found it reduced the clunk into 2nd very noticably. As the oil gets older the effect is less, but if you change it regularly it will help.
I've been reading through old posts to see if anyone has made a real connection between oil and clunky gearboxes - I don't know if it's peculiar to my 'Storm' but whilst the engine is cold (and the oil is thicker??) the gearchange, even first to second is sweet as a nut but as it warms up the changes get clunkier & clunkier.
Does anyone know if any particular type of oil will help?
Haydn.
Haydn.
- paddy_skipton
- Contact:
Paddy,
I know what you are saying, clutchless changes and a 2 stage (1st to neutral - neutral to 2nd) change between 1st and 2nd work well, the point I am trying to make though is that whilst the engine is cold the gearchange is silky smooth, even 1st to 2nd, which I guess is due to the cold oil being more viscous. I wanted to know if anyone has experienced a particular type or brand of oil improving the gearchange significantly.
Haydn
Haydn
- Rollingalong
Have you seen the newest EVO-7 shift kit from Factory ?
It has a different shift star , detent on a roller bearing and the old style detent spring .
Cool and quite pricey but I bought one anyway . I'll report if it works or not next spring ...... long time ehhh?
It's motor building time here and the stuffs all tore down .
