Help with Battery!
Re: Help with Battery!
A lot of these "Smart Chargers" will not charge a battery if the voltage is too low. (About 6 Volts). Have you put a multimeter on it to see what voltage is there? if it is below 6V then a good old fashioned charger will be required to charge it initially above the smart charger low voltage cut off point.
Optimate works down to 2v soslipper 1 wrote:A lot of these "Smart Chargers" will not charge a battery if the voltage is too low. (About 6 Volts). Have you put a multimeter on it to see what voltage is there? if it is below 6V then a good old fashioned charger will be required to charge it initially above the smart charger low voltage cut off point.
![Tongue2 :Tongue2:](./images/smilies/Tongue2.gif)
She told me she was 16.
Do you notice significant difference with this battery considering the recommended battery for the storm is 10mAh this is labeled as a 14, which does not follow the model codes.bigspanishmarty wrote:a few of us have bought one of these via ebay £50
very good with 4 terminals so you can wire up other things to it aswell......
MOTOBATT MBTX12U UPGRADE BATTERY YTX14-BS / CTX14-BS
mad4bikes
Perhaps, but it wasn't entirely his volt.Phimosis wrote:Wow is that classified as Assault on Battery....simo wrote:If you can get your hands on an old style battery charger which can push 9 or 10 amps and give it a good stinging until it bubbles and boils, that will do it.Works for me![]()
Watt lead him to it?
He was positive it would fix his cycle, but in the end- guilty as chargered.
all i know is my bike now has an eagerness to start, and there seems to be no bad side effects bazza........bazza696 wrote:Do you notice significant difference with this battery considering the recommended battery for the storm is 10mAh this is labeled as a 14, which does not follow the model codes.bigspanishmarty wrote:a few of us have bought one of these via ebay £50
mad4bikes
Help with Battery!
in danger of this prose going unnoticed, I thought I'd give you props for it. ;)tony.mon wrote:Perhaps, but it wasn't entirely his volt.Phimosis wrote:Wow is that classified as Assault on Battery....simo wrote:If you can get your hands on an old style battery charger which can push 9 or 10 amps and give it a good stinging until it bubbles and boils, that will do it.Works for me![]()
No bike (yet).
Faraday Tony you will be funny.tony.mon wrote:Perhaps, but it wasn't entirely his volt.Phimosis wrote:Wow is that classified as Assault on Battery....simo wrote:If you can get your hands on an old style battery charger which can push 9 or 10 amps and give it a good stinging until it bubbles and boils, that will do it.Works for me![]()
bought one on your recomendation but have not fitted yet, wanted to wait till I have serviced the old girl then do a video comparison for the forum.bigspanishmarty wrote:all i know is my bike now has an eagerness to start, and there seems to be no bad side effects bazza........bazza696 wrote:Do you notice significant difference with this battery considering the recommended battery for the storm is 10mAh this is labeled as a 14, which does not follow the model codes.bigspanishmarty wrote:a few of us have bought one of these via ebay £50
mad4bikes
i doubt you will be dissapointed buddy, my mechanic has robbed mine, the little so and so
i will have to get another one no doubt, i will deffo be hooking up a trickle charger to the extra terminals![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
on the subject of battery's I use my storm for work witch means I have to start the bike up to 40 times a day 5 days a week with only short runs in between Never once has the battery let me down in the last 15 months and its not even a yusa or motobat .just a cheep dynovolt ytx14
and its not kept on a tender overnight ether ![Very Happy :D](./images/smilies/icon_biggrin.gif)
