The engine in the bike with no air box on it?
I need to see where the side covers (little black plastic things go)
Thanks
Any one got a photo of
- thumperslaw
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Sorry the only ones I have
- thumperslaw
Re: Any one got a photo of
Perfect.
First photo its got that black tray thing under carbs
Me needs that!
Me needs that!
K100 "flying brick"
K100 "flying brick"
Dont know if this is any good it's a bit biased to the left hand side?
http://www.ixxra.co.uk/v-web/phpBB3/dow ... e21a0a6940
The two smaller pieces that attach to the tray are easy to fit; one has a 90degree bend to it and secures with a trim clip under the frame rail, the other secures with a trim clip to the triangular section (that's the LH one).
RH one goes round the throttle cables, the LH one just blocks the hole behind the front coil.
But interestingly if you fit stick coils, you can remove the front coil, and that piece of trim plastic, and that's route into the airbox area for ram air.
- thumperslaw
I never fitted the black try back on my storm after i swapped engine over
Found that caused it to run like sh1t
K100 "flying brick"
K100 "flying brick"
